Carb for Speedester
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Carb for Speedester
Post by Mustang1964s » Sun Aug 28, 2022 1:28 pm
I am thinking of having or trying to rebuild this carb.
What is the consistence of putting this on a speedster?
Re: Carb for Speedester
Post by Scott_Conger » Sun Aug 28, 2022 1:52 pm
It's a good carb for a mildly massaged speedster
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Aug 28, 2022 2:04 pm
Hi Steve,
It will look very nice all polished up, It may interfere with the generator, I think the original manifold set the carb back some. Throttle linkage will be a little challenging. I think that is a U & J manifold. I have a very similar manifold on my speedster ( no generator ) with a model A replacement Marvel-Shebler carb so I can adjust the fuel mixture to my needs. When I had a generator on the car I made a adapter to set the carb back far enough to clear it.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Aug 28, 2022 2:21 pm
That carb or not... the manifold is a great start! I run a Winfield S-AA on the same manifold, very happy!
Mustang1964s
Post by Mustang1964s » Sun Aug 28, 2022 3:38 pm
I just held it up to the inlet ports. The carb intake is facing the alternator.
Will that be an issue with rain?
The accelerator linkage will need some reworking. The rod that goes through the block has the push/pull in the wrong direction.
Post by Scott_Conger » Sun Aug 28, 2022 6:09 pm
You will need to come up with a bell-crank arrangement akin to this (courtesy of Donnie Brown):
zzzzzzzz (18).JPG (32.5 KiB) Viewed 2170 times
zzzzzzzz (16).JPG (46.64 KiB) Viewed 2170 times
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Aug 29, 2022 9:37 am
Nice Set up Scott!
Super Mario Bross ;)
1911 Touring
1914 Speedster
Post by Scott_Conger » Mon Aug 29, 2022 9:43 am
Hi Mario
that set up belongs to Donnie Brown...he's the author of that artistry
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Wed Aug 31, 2022 3:18 pm
Um - WHAT?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Post by Scott_Conger » Wed Aug 31, 2022 3:23 pm
Steve
with carbs like this, the rebuild process typically involves the bushing of the throttle shaft and manufacture of a new shaft. If the rebuilder knows the intended application, an extended shaft is made so as to effect actuation from which ever side you need or desire.
Carbs manufactured like the OE-1 really should be mounted with the bowl "forward" and intake facing rearward, so your question is a valid one, and this is the answer.
A shaft for an OE-1, mounted bowl-forward (economizer facing the engine) would look like this:
