Good day everyone
Im looking for a dyno spark advance curve for model Ts
That would be a graph with spark on the vertical axis and rpm on the horizontal axis at maximum torque.
Spark advance curve
Re: Spark advance curve
Is your engine and ignition system stock? If not, how is it modified? Correct spark timing in any particular instance depends on a number of factors. Stock torque maximum is around 900 RPM. A stock T engine can take a good bit of advance at that speed using pump gasoline.
