In need of a float for a Holley S. Reproduction not made. Holley G float too large.
a) Is there a substitute that can be amended/tweaked?
b) Is there someone who has one for sale?
c) Has anyone trimmed a modern material G float to create an S float?
d) Is there a coating that can be applied onto the original cork float to prevent gasoline absorption?
e) Does anyone have a Kingston modern material float for sale...thinking it maybe a comparable size for an S float?
f) In need of a brass bowl for the Holley S also.
Holley Model S Carb
Re: Holley Model S Carb
You're going to simply have to make one. Vendors sell the material to do it.
NOTE: it is more buoyant than cork, so you will have to carefully and laboriously whittle it down "skinnier" than the old cork one before you get to the correct fuel level
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
Hey Jay,
A few years ago I had the same problem.
Here is what I did.
The float that was in it before was a Holley NH float and it worked well with a little change on it at the hinge.
I think the gaskets were available.
Goodluck
Andre
Belgium
Here is what I did.
Goodluck
Andre
Belgium
jaybee47
Topic author - Posts: 349
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Andre. Earlier I explored using an NH float. It seemed to me that it would be compatible with a little tweaking on the lever. Thanks for confirming that it will work.
This would be easier than making a new one. I was also advised in a different forum that a John Deere float AR10067 would also be very compatible. Looks like your bowl had cracks. Mine has cracks too. I'll solder from the interior if I can't find/buy a good one.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
