Steering bracket
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Steering bracket
Post by fordt » Mon Sep 12, 2022 7:54 pm
Quick question, this steering bracket should only have one bushing in it….on the opposite side of this shaft opening….right? And this is just a test fit, don’t give me grief about color/finish!🤪
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Re: Steering bracket
Post by TMiller6 » Mon Sep 12, 2022 8:35 pm
Yes, you are correct. One bushing installed from the bottom.
Tom Miller
Post by Original Smith » Mon Sep 12, 2022 9:42 pm
The early brackets had a long one piece bushing. The later ones had two short bushings. Don't forget the felt.
Last Name: Humble
Post by Humblej » Mon Sep 12, 2022 9:45 pm
What year are you asking about Rob?
fordt
First Name: Rob
Last Name: Trippet
Post by fordt » Tue Sep 13, 2022 7:33 am
26-27…..Frankencar here had a different one, but the previous owners must’ve used smaller bolts to make it fit cuz the holes in the frame didn’t quite match up, the other one had the protrusion for the felt washer on the top end. This one fits correctly, at least frame hole wise….I’ll have to ream a bushing for it….don’t see a place for felt on this one!
Thanks!
