Post
								by Wayne Sheldon » Wed Sep 28, 2022 4:02 am
			For whatever it is worth.
A few years ago, at a swap meet I bought what I suspected was an original brass sediment bulb for my 1915. It was in pretty nice condition overall, not complete, and had some minor damage where the front piece threads in. I managed to straighten the damage, but the front piece that came with it would NOT thread in all the way, in spite of everything looking so good after I straightened it.
So I decided to try a couple other front pieces. I grabbed the box of mostly junk sediment bulbs and pieces I had left over from previous restorations. I needed it anyway because the shutoff lever (and tapered piece!) was missing. One of the loose front pieces threaded in just fine, but it looked so bad I didn't want to consider using it! The other two loose pieces did not want to thread in, and one of them was also pretty ugly.
So I decided to take apart a couple other ones, ones I had given up on years earlier.
All those tips and tricks to take them apart mentioned above? I did them all and then some! I soaked those sediment bulbs in mild acids to remove rust and corrosion for a couple weeks! Mild heat (about 400 degrees F!) and cool cycles. Clamped the front piece square into my big blacksmith vise, and double hammer tapped the "potato" to try to knock it loose. After a couple hours, one of them came loose. A day later, and another couple hours, and more heat, another one did. Oh, and that time? the lead gasket flowed away from the heat!
Finally (well, not quite yet?), I had two front pieces that would thread all the way into the brass "potato". And one of them looked alright.
You know? I never did figure out WHY two of them would fit in, and four others would NOT! All of them would fit fine in a couple decent iron "potatoes". I suspect some minor imperceptible distortion in the brass "potato"? I did have to straighten it slightly and very carefully?
The "not yet" finally? One iron sediment bulb never did give up its front piece. After too much time spent trying to get the pieces apart without ruining them? It I also got really hot, tried a whole bunch of tricks I knew of. But the front piece still looked really nice. No known flaws in the "potato". So, as much as I hated to do it? I hack sawed the iron "potato" and split it off the brass front piece. I do not like to destroy a good piece, but I do have a couple yet for future restorations. And that front piece ended up being the one I used.
As for that longer lower cast tube inside the "potato"? The brass one I bought doesn't have that. Most of the iron ones I have had over the years did not have that (according to my recollection?). However, I do recall at least one years ago that had that. I thought it was odd at the time. The five or so iron ones I had in my junk box and spent so much time getting apart? ONE of them has the long tube as part of the original casting. So they are out there.
What that means? Or when which were used? I have no idea.
