Reproduction brass hub caps?
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Sun Apr 21, 2019 8:27 pm
Another question for the combined knowledge of the board... the parts box that came with my car included these four brass hub caps.. the car only had one old cap on the car.
I think the one on the car is original, given the clean definition of the letters, and the four brass ones are reports, given the less clean stamping and differing 'made in' font. Do you guys agree?
Thank you in advance for your time and opinions.
Andy B.
Believed to be the original cap.
Reproduction??
Reproduction??
Re: Reproduction brass hub caps?
Post by Original Smith » Sun Apr 21, 2019 8:47 pm
Yes.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Apr 21, 2019 10:42 pm
You learn quickly, Grasshopper.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Apr 22, 2019 12:39 am
Here are a couple original caps that have slight differences. Then an original next to a reproduction cap I was practicing painting the background.
Post by Wayne Sheldon » Mon Apr 22, 2019 1:06 am
The higher "swoop" of the top of the "F" shown on three of the four hubcaps pictured by Corey W are earlier, and more desirable. Larry Smith is the expert on this detail. But I "think" the "high F" caps are basically a one year variation used late '12 and nearly all of 1913. I could be wrong on the specific timeline.
If I recall correctly, the true 1912 hubcaps had the same "High swoop" script, but no "MADE IN U S A", and script was centered.
Post by Wayne Sheldon » Mon Apr 22, 2019 4:26 am
Some great information was added by Keith Townsend to this other thread that I had missed.
viewtopic.php?f=2&t=3148
Post by Original Smith » Tue Apr 23, 2019 9:48 pm
I believe both the hubcaps on the mattress pad are '13s. They have a much bigger script than the '14-17 style. I've been collecting these for years, and there is a definite difference.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Wed Apr 24, 2019 6:05 am
Thank you all! I plan on making the repros a little more worn with the blackening agent that has been discussed until I can find suitable originals. Cheers!
Andy
Rosenfelder
Last Name: Rosenfelder
* REQUIRED* Type and Year of Model Ts owned: 1927 Model T touring
Post by Rosenfelder » Wed Apr 24, 2019 11:28 am
I bought a set of new nickel plated hub caps for my '27. Some of the originals on the car don't fit well (slightly loose). Several of the the hub caps in my spare parts collection were cracked and are even looser. The reproduction hub caps don't seem to want to thread onto the fine threads of the hubs. I'm not sure if it is because the threads are damaged. Leaving the originals on for now.
