Bending Bendix washers
tom_strickling
Topic author - Posts: 448
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Concerning bendix spring bolt washers. Does it matter where the tab that bends down rests? Should it touch the outer surface of the bendix spring or should it be down in "the gap" and the end of the spring?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
Re: Bending Bendix washers
I always put mine in the gap!
like they say in the gap
https://www.mtfca.com/discus/messages/5 ... 1461451254
Dan Treace, North FL on Saturday, April 23, 2016 - 12:57 pm:
Moxie26
- First Name: Robert
- Last Name: Jablonski
The other tab of the lock washer has to be bent to match one of the flats of the bolt
tom_strickling
- First Name: Tom
NICE photo Thanks Frank and everyone else
tom_strickling
- First Name: Tom
And DAN for the original photo
For the tab that is bent up, I get mine just started bending before installing. Makes it easier to bend rest of way up after installing. The new ones are hard as heck and is why they should never if you can help it, reuse.
J1MGolden
- Last Name: Golden
I always bend the other tab up a little bit, the bend it the rest of the way with a large pair of water pump pliers.
Other directions have noted the starter shaft can be bent by hitting that tab with a hammer to compete the bend.
