Operating Centerdoor Windows
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Mon Oct 03, 2022 1:06 pm
I have seen pictures of Centerdoor T's with the side window down. We have a 1920 Centerdoor, with a strap that hangs off the base of the window. How do you operate the windows?
Re: Operating Centerdoor Windows
Post by Rich Eagle » Mon Oct 03, 2022 1:14 pm
They are similar to these TT straps:
http://www.mtfca.com/discus/messages/11 ... 1287772854
Maybe this is more help. I don't have a Centerdoor.
http://www.mtfca.com/discus/messages/82 ... 1546222046
Post by RajoRacer » Mon Oct 03, 2022 1:15 pm
We have a '19 - you need to pull up on the strap (carefully) to get the window & base off the small ledge holding the window up in place then simply pull inboard a smidgen & lower the glass. I believe the door window has or should have a couple holes in different spots for adjustment - just the door windows on our car, the rest are up or down.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
* REQUIRED* Type and Year of Model Ts owned: 26 coupe and 23 Runabout
Post by Stephen_heatherly » Mon Oct 03, 2022 1:26 pm
I have a 1919 centerdoor as well. Only the door windows have the holes in the straps to adjust the windows.
Stephen
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Mon Oct 03, 2022 6:42 pm
Thank you. So the way I understand it is the strap holds the bottom of the window inside the door. The window frame has a tab on the inside that hooks up with a hole on the strap that holds the window. Did I get it? :?
Post by RajoRacer » Mon Oct 03, 2022 8:11 pm
Here's a few photos of ours.
