Here is a set of small drum Bennett outside accessory brakes, equalizer, and pedal.
The brakes have some wear on some of the parts. There were no linings on them when I got them. One brake is missing a small bracket and spring. The bracket is just a piece of flat steel bent on a 90 with two holes drilled in it so it should be easy to make. The spring should be easy to find at a good hardware store.
The equalizer is a Bennett and looks to be in good shape.
The pedal is a Rocky Mountain pedal. It has some ugly welds that should be cleaned up and redone.
Asking $300 plus shipping for everything. Please send me an email (not a private message). My email address can be found by clicking on my profile.
For Sale: Small Drum Bennett Brakes, Equalizer, & Pedal
- First Name: Jeron
- Last Name: Takacs
- * REQUIRED* Type and Year of Model Ts owned: 1919 Touring and a 1924 Coupe (all original)
Re: For Sale: Small Drum Bennett Brakes, Equalizer, & Pedal
I’m interested in these!
Topic author - Posts: 805
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
Brakes are sold.
Thanks MTFCA!
Thanks MTFCA!
- First Name: DAN
- Last Name: MCEACHERN
The weld on the pedal is because someone welded a Ford brake cam onto the pedal. RM pedals had no brake cam on them.
