Model T Braking
Topic author - Posts: 1203
- First Name: Adrian
- Last Name: Whiteman
Model T Braking
Model T Braking
As part of our semi-annual mechanical inspection necessary to register the car and use it on the road, the inspector has to test the braking.
A modern version of the 'Tapley Meter' is used. It measures the forces when the brakes are applied using an accelerometer.
Anyway, the minimum reading to 'pass' is "50" (somethings!)
Yesterday my T Roadster locked up the rear wheel with a skid along the seal. Meter reading was "41". "Well.." said the inspector,"you can't rally get better brakes than locking up the wheels" - Result: "pass".
It is refreshing to see there are sensible folk out there!
Re: Model T Braking
Best braking is obtained just short of wheel lockup. Ideally, both wheels will lock up at the exactly the same degree of brake application, which will allow the driver to exploit the full available braking capability. Model Ts drivers have access to both the service brake and the parking brakes, and both can be used in emergency situations. Reverse can also be used in emergency situations. Tire condition and pressure affect braking ability, as does vehicle loading and load distribution and road surface characteristics. A T engine tuned to permit a slow idle speed setting prevents needless brake wear and improves overall braking control. It's unlikely that an inspector who is unfamiliar with the Model T, particularly your Model T, obtained maximum available braking on a first or second attempt.
Chris Barker
- First Name: Chris
- Last Name: Barker
Re: Model T Braking
Physics tells you that if you have 2 wheel brakes, 50/50 front/rear weight distribution and no weight transfer under braking (which is impossible), the best you can hope for is 0.5g or 50%.
0.41 is very good.
0.41 is very good.
Re: Model T Braking
I think you'd have some "weight transfer" from rear to front.
George Mills
- Last Name: Mills
Re: Model T Braking
Somewhere in the past...the late Ralph Ricks delved deeply into this subject as part of his Nash Rambler hydraulic brake project for his yellow pick-um-up truck that was originally in that Great American Race tribute recreation (pre brakes?) I have no luck at searching this forum, even using google search...but I believe that by the time he was done Ralph had disclosed everything anyone wanted to know about the kinematics of braking in a Model T???
(Hoping to jog someones memory)
Art M
- First Name: Art
- Last Name: Mirtes
Re: Model T Braking
Pat,
The weight transfer due to braking is a function of braking g's and the height from the road surface to the vehicle center of gravity.
Art Mirtes
Art Mirtes
Re: Model T Braking
... Also torque from braking applied to the rear engine mounts, and any fluids shifting forward. Unicyclists are keenly aware of the dynamic effects of braking, as are motorcyclists.
m_p_dean@yahoo.com
- First Name: Maurice
- Last Name: Dean
- * REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
Re: Model T Braking
Or, just politely explain that braking/stopping is over rated, and gets you nowhere. Unfortunately, it may have failed an acceleration test also.
Luke
- First Name: Luke
- Last Name: P
Re: Model T Braking
I have an idea Adrian may yet have further revelations from this day...
JohnH
- Last Name: Hunter
- Board Member Since: 2002
Re: Model T Braking
The initial inspection of my T when I first got it registered was a bit of a joke. The display on the brake tester blanked out because of the Model T's unique ignition system. A somewhat pedantic guy was doing the test and wouldn't give up - so we ended up letting the car roll down a hill with the engine off. The handbrake test easily passed (it's a 26), but the speed at which the car rolled down the hill was not enough for the foot brake test. Eventually he was forced to give up and just pass it, after several hours of trying!
The guy I've used for the annual inspection since then has a bit more common sense.
Re: Model T Braking
Sean Butler
- First Name: Sean
- Last Name: Butler
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Luke
- First Name: Luke
- Last Name: P
Re: Model T Braking
I'm not surprised, your 'hills' are just an extremely gentle undulation over here!
Otherwise good to hear you've found someone more sensible - better still the WA or Tassie system where there is no annual inspection (or in our case 6-monthly
Luke
- First Name: Luke
- Last Name: P
Re: Model T Braking
... so, since the originator of this thread won't 'fess up ... rumour has it that his Model T actually had better braking than another vehicle he has, despite it (the T) missing vital suspension and exhaust components
Also, Mr W, apropos our earlier discussion - it's not really how you spell 'really'
