spare tire bracket
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
spare tire bracket
Post by Melba Nolan » Mon Oct 17, 2022 12:01 pm
Does any one have a picture of how the brass tire carrier for the running board mounts.
Re: spare tire bracket
Post by DanTreace » Mon Oct 17, 2022 2:19 pm
Here is one way to install. The twin brackets fitted to a board, painted to match body, with the board bolted to the existing running board bolts.
Each bracket holds a tire at the base with a leather strap.
Dual leather straps above hold the two tires together.
Melba Nolan
First Name: Melba
Last Name: Nolan
Post by Melba Nolan » Mon Oct 17, 2022 2:30 pm
ok if the 2 small ones go on the board where does the larger bracket go.
Post by DanTreace » Mon Oct 17, 2022 6:03 pm
The longer bracket for the upper cradles a tire, the long male spade portion is mounted to the dash.
