OK MA! Your turn!
Re: OK MA! Your turn!
Another 32 wonderful photos! A few repeats, but you won't hear me complaining.
Numbers 8 & 9 are the same 1913 Ford touring car, with a slight rearrangement of the passengers. A great car to be sure! Most notably, it appears to be a right hand driven Canadian car. Numbers and "Ford" script are facing right. Also, the driver's door has hinges.
Note also the electrified headlamps.
Number 26, a 1914 runabout, is also a Canadian right hand driven car! Again, the "Ford" script is correctly showing, and the driver's door has hinges.
Note how the horn bulb is mounted under the top end of the steering column.
Number 23 (if I didn't miscount?) appears to be a 1917 folding top couplet. What is interesting about it, is the rear sides of the top does not have the small windows added to the couplet very late in calendar 1915 for the 1916 and later models?
It also has some nice aftermarket Firestone type demountable rim wheels. I should mention that Firestone was one of several companies that manufactured or marketed similar wheels. There is quite some history there. Licensing agreements, patent infringements, mergers, acquisitions, selloffs. Perlman circled the world, Jaxon (later famous for their steel disc wheels), and others were involved. Most of them looked very much alike unless you can get very close. That is why I usually identify them as "Firestone type" wheels.
Numbers 14 & 15 show a 1912 (?) with a wonderful after-market electric starter! Don't see ones like that very often! Can you imagine trying to maintain it and keep the gears and all clean enough to use it? Splashing in the mud? Dry dusty roads coating the the necessary oil in dust?
Mark Nunn
- Last Name: Nunn
Wayne, I'm not convinced that the aftermarket starter is electric.  The connections look less like electric cables and more like hose connections.  Could that be pneumatic?  Someone (Dan?) may have an advertisement for it.
- Last Name: Wrenn
I think those are elec. cables..they gotta be pretty heavy to run that beast! Also, where in the world would the air pressure come from to be a pnuematic starter in the first place? Pics 8 & 9 of that '13 are indeed great clear pics as well as of a great '13. The second pic does a great job once again of settling any questions regarding the correct boot to with that little flap on the top edge. So many repos do not come that way and it's just a shame. Trust me, my Clarabelle has them!!
				BobShirleyAtlantaTx
- First Name: Bob
- Last Name: Shirley
The chain MIGHT be considered a liability in today’s market, YOU THINK?
- Last Name: Wrenn
Ya, how true! I can see kids sticking their fingers in it while daddy's cranking it over!!BobShirleyAtlantaTx wrote: ↑Wed Oct 19, 2022 8:59 amThe chain MIGHT be considered a liability in today’s market, YOU THINK?
Definitely not OSHA approved.
Mark Nunn
- Last Name: Nunn
Tim, there were pneumatic starters on the market.  A storage tank was pumped up during engine operation but I don't know how, a belt driven pump, I suppose.  I saw a photo of one on a Lozier some years back.  The problem with pneumatic starters is that you only get one chance to start an engine.  Then it must be hand cranked.
Looking at the photo again, I agree that is must be electric given the severe gear reduction involved.
Mark N, It is an interesting thought that hadn't occurred to me. It could actually be an air starter? Although looking close, I suspect it is electric.
A longtime good friend has a late 1911/early 1912 Pierce Arrow with an air starter from the Pierce Arrow factory. It was a very original car, then restored in the 1950s. When they re-restored the car about twenty years ago, they had the starter system completely rebuilt and made functional. It is quite something to see and hear used!
I can't recall ever seeing one of the after-market air starting systems, but I do know that they were marketed to fit almost any make of car.
Fun stuff!
Fun stuff!
				Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Is the car with the two guys wearing stove pipe hats a Model F Ford?
Stove pipe hats. Not a Ford.  Probably picture made in early 1930's because the car in the background looks like a 1930 Model A or or that vintage.  The springs on the car with stove pipes are not transverse like a Ford.
- First Name: Tom
- Last Name: Rootlieb
Herb and Norman, I could be wrong(usually am) but when I first saw the picture I thought it was a Model C.
- Last Name: Wrenn
Thanks Mark...again, good to learn new stuff. I did indeed "wonder" if maybe I was wrong and there could've been a pnuematic, and instantly figured if it was, it'd be a "one shot" deal...not very user friendly in my book, eh? Thanks for your post.Mark Nunn wrote: ↑Wed Oct 19, 2022 1:37 pmTim, there were pneumatic starters on the market. A storage tank was pumped up during engine operation but I don't know how, a belt driven pump, I suppose. I saw a photo of one on a Lozier some years back. The problem with pneumatic starters is that you only get one chance to start an engine. Then it must be hand cranked.
Thorlick
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
The picture I absolutely love is number 19.  It appears to be a Ford Laundalet.
The seat support and floor riser seem to have very plain craftsmanship in contrast to the body. The rear fender looks to be home made also.
The text on the building and the uniforms as well as the left hand drive and American Red Cross stencil might put this in France late in the war (1918?).
Even if it is not one of the rare as hen's teeth original Model T's of this style, I would still love to have it. I am sorry I sold my 1913 (reproduction) RHD New Zealand Fire Brigade car, which I now miss!
IMHO, TH
IMHO, TH
Terry Horlick,  Penn Valley, CA
- First Name: Tom
What do you think? Model C?
Looks like it!
				Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
By Georg, I think you got it!
Hey there Terry H!
Yeah, I was surprised when you put it up for sale! But life is like that sometimes.
I am fairly sure the landaulet is a French built body. Shipping during the wartime was mostly limited to necessities (war, medical, or life) and full bodied cars took up too much space. Craftsmen only needed a small shop to turn out good bodies quickly. Somewhere years ago, I saw a wartime photo taken in France showing such a shop rebuilding model Ts largely destroyed in battle! There was a small building, and most of the final assembly and some repair work was being done in the street.
Rob
- First Name: Rob
- Last Name: Heyen
Thank you as always for the photos.  Yes, Model C.  I’ve seen it before, and I believe it may have been at a fair or event in England or Europe.  Anyway, the photo is identified somewhere.  Maybe I can find it.
Thanks again.
						Thanks again.
				Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
