Crankshaft
Jim-B
First Name: Jim
Last Name: Boyer
* REQUIRED* Type and Year of Model Ts owned: 1927 T truck. 1927 T roadster
Crankshaft
Post by Jim-B » Tue Oct 25, 2022 1:32 pm
While digging potatoes the digger unearthed this, wonder if it is salvageable ?
Moxie26
Last Name: Jablonski
Re: Crankshaft
Post by Moxie26 » Tue Oct 25, 2022 1:36 pm
Boat anchor ????
Re: Crankshaft
Post by Rich Eagle » Tue Oct 25, 2022 1:55 pm
Someone would love to have it hanging in their shop or mancave, a great conversation piece.
I would think it is pitted too deep to grind to a useable size. Maybe it could be metalized but with so many around it is doubtful it would be worth the cost.
How are the potatoes this year?
It's fun to see it.
Re: Crankshaft
Post by Jerry VanOoteghem » Tue Oct 25, 2022 3:55 pm
Well, it's not broken at least. That makes it better than a lot of them out there! Neat find!
Re: Crankshaft
Post by Norman Kling » Tue Oct 25, 2022 4:00 pm
If you have a local historical museum, you might donate it. We actually have some Model T parts which were found buried under our main street when it was excavated for undergrounding utilities. They are in the museum.
Jim-B
First Name: Jim
Last Name: Boyer
Re: Crankshaft
Post by Jim-B » Tue Oct 25, 2022 5:21 pm
Rich, potatoes are ok, maybe a little smaller then usual
OilyBill
First Name: William
Last Name: May
Re: Crankshaft
Post by OilyBill » Tue Oct 25, 2022 7:46 pm
I can tell that NONE of you are farmers!
It was traditional in the 1920's, if you broke a Model T Crankshaft, to take the smaller piece, bury it in the ground with a piece of potato or a fish from a local stream, and then come back in 30-60 days and pluck your new crankshaft right off the bush!
It works for REO's and Brushes, too!
Dave Sullivan
First Name: David
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1923
Re: Crankshaft
Post by Dave Sullivan » Tue Nov 01, 2022 10:11 pm
Bill, you still got to grind it, though, right? Dave in Bellingham..
Last Name: Tannehill
Board Member Since: 2002
Re: Crankshaft
Post by JTT3 » Tue Nov 01, 2022 10:17 pm
Oh it really is salvageable, just take it to the scrapyard they’ll give you a few cents per pound for salvage.
Re: Crankshaft
Post by TXGOAT2 » Tue Nov 01, 2022 10:54 pm
Before I let the Chinese get it, I'd make chisels or punches or pole shoe bits or whatever out of it... or clean it up and hang it up for a dinner bell, or just hang it on the wall to look at. Many years ago, me and another fool agreed to tear down an old commercial building in exchange for a 1952 Cadillac convertible. It turned out to be quite a job to demolish the building and clear the lot. One of the back doors had a concrete step. I took a sledge hammer to the step to to break it up into pieces I could pick up. After a couple of whacks, the step split apart to reveal about 3/4 of a Model T crankshaft which had been used as rebar. It had broken in service. I'd guess that the building, which once housed a steam laundry and a grocery store, was built in the 1920s.
