Brass Era light
Topic author - Posts: 694
- First Name: Michael
- Last Name: Peternell
Brass Era light
I came across this light and would appreciate any insight as to what it was originally used on.
Thanks in advance!
Mike Peternell
Thanks in advance!
Mike Peternell
Re: Brass Era light
Name on it says Velie. So it’s off a Velie.
- Last Name: Tannehill
Re: Brass Era light
Re: Brass Era light
This link gives history of Velie. And has links to parts wanted if that lamp needs a new owner.
https://veliepartsboard.com/mtvelie/Mtvelie2.html
Re: Brass Era light
This is a 1910 Velie with Rushmore lamps. I think the lamp forks may be the same.
FWIW
FWIW
Re: Brass Era light
Thanks gentlemen!
I figured it would be as easy as asking the question!
Re: Brass Era light
I'd want to see if any other Velie parts could be found wherever that headlight turned up.
