Exhaust manifold threads
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Mon Oct 31, 2022 10:24 pm
Looking for the size and thread count on late model exhaust manifolds. Also any sources for the appropiate die
Thanks in advance
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Exhaust manifold threads
Post by Pep C Strebeck » Mon Oct 31, 2022 11:22 pm
1-7/8 x 16 tpi.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Mon Oct 31, 2022 11:24 pm
Post by Jerry VanOoteghem » Tue Nov 01, 2022 12:07 pm
Here's a die for $42.00. I bought one a while back. Pretty nice quality but took a while to arrive from China. I had to break my rule of not buying from Chinese sellers, which was hard pill for me to swallow.
https://www.ebay.com/itm/233249148019?h ... R4r19L6GYQ
Post by Steve Jelf » Tue Nov 01, 2022 12:08 pm
The last time I saw one of the new exhaust manifolds it was the 25-27 style. If you want the earlier type it may have to be an original.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Nov 01, 2022 12:08 pm
A friend of mine, who also participates in this thread, had a manifold with unsalvageable threads that he was desperate to save. He took it to a machinist who cut off the damaged threaded end and then made a new end with more common coarse threads and welded the end to the manifold. Then the machinist made a new nut (from steel) with threads to match the new threads on the manifold. I'm sure he had a manifold worth its weight in gold by the time all was said and done, but with the nut screwed on, you can't tell its not original.
Post by TXGOAT2 » Tue Nov 01, 2022 12:13 pm
If you can deal with the welding aspect, a common pipe union could be adapted for connecting header pipe and manifold. Welding might be avoided by inserting a pipe nipple or short length of exhaust pipe in the manifold outlet and securing it with a bolt.
Post by John kuehn » Tue Nov 01, 2022 3:12 pm
I bought a new one for my 21 Touring. Worked fine for me.
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Tue Nov 01, 2022 11:22 pm
Thank you to all that responded. I do greatly appreciate it
