Spring perch for what?????
Topic author - Posts: 361
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Two sets of spring perches for an unknown car. I hope the someone can identify these items. I found in my model t stuff. If anyone can use them let me know. The look to be nos. The spring shackler length is 1 3/4" on both sets The hole size on the longer set is 3/4" The hole size on the shorter set is 5/8"
- Last Name: Wrenn
Re: Spring perch for what?????
Cute little things ain't they!?!
- Last Name: Hjortnaes
Looks like 26-27 rear perches.
- First Name: Robert
- Last Name: Jablonski
Yup, I agree
Dave.
They are not 26-7.
.... Can't stand the suspense, what car is it from Speedy John ???
- First Name: Kevin
- Last Name: Matthiesen
I don’t know for sure what car they are from. But on a 1926-27 T rear axel they look like they would lower or lift the rear almost one inch. So they may have been for a roadster pickup with a extra leaf spring. On a speedster to get a little lower used with one less leaf.
If those are Ford perches there should be a T part number on them. You can barely see something on them but it’s not a clear shot where the supposed no. might be. I was thinking they were the earlier perches but not quite.
I have most all Ford parts books - not a Model T part.
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Could be replacement perches that went with an accessory shock system so the chassis stayed at Ford standard.
Tim Moore
Tim Moore
- First Name: Tom
On the longer perch there is a G DUC and a number3034 If that will help. They look like the could be 26/27 replacements Tom
This was my first thought also.
Purely speculation. I have not seen these in any of my accessory books.
The shorter version could be used to raise the back end up(26-7) to compensate for a weak spring, or heavy loads such as a calf, goats or a mother-in-law.
Reversing down would cause the spring to ride the axle tubes. So thats a no.
Could be part of a lowering system for a racer to hang the spring in front of the axle & tied to the radius rods.
Could be for one of any number of other period automobiles. If so, someone will recognize them.
If the Model T Front spring is 1-1/2" wide & the rear 2" wide how could these be used on a Model T, accessory shock or not?
You know, not every car back then was a Model T....
- First Name: craig
- Last Name: leach
Hi Tom,
What would you take for them?
Craig.
Craig.
- First Name: Tom
Creig:
I would take $40.00 For the pair plus postage which will go into a small flat rate box at $ 9.85. These look to be New Old Stock. Tom
- First Name: Pete
- Last Name: Eastwood
Looks like an old hot rod component made by "PSI". They made a lot of "ductal" iron suspension pieces.
