transmission bands Questions
Re: transmission bands Questions
Post by Jerry VanOoteghem » Sun Nov 13, 2022 10:15 am
I would think so. I imagine you'd have to remove the brake band first, then slide the low band back and remove it, then slide the reverse down and do it last.
Post by RajoRacer » Sun Nov 13, 2022 11:18 am
As Jerry eluded to, yes but you'll need to bring one band at a time back near the clutch spring & past the internal brake pedal boss in order to drop the attached ear down into the abyss whilst removing the detachable ear then remove the band.
