Ruxtel and Rocky Mountains
Topic author - Posts: 380
- First Name: Don
- Last Name: Ellis
I’m sure there’s a way to run both but my shifter is hitting the rocky linkage from the brake pedal. Do I have to run the hand brake shifter or something?
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: Ruxtel and Rocky Mountains
Try turning the shifter around so the spring is on the other side.
Your shifter is mounted backwards.Fire_chief wrote: ↑Fri Nov 25, 2022 12:24 pmTry turning the shifter around so the spring is on the other side.
- First Name: Don
- Last Name: Ellis
Sometimes you can’t see the forest for the trees, thanks
One thing few folks know about Ruckstells, is when Eaton took over production from Hall Scott, they changed the design of the patent plate, to the clipped corner design which some people think is the 1926-7 design. Yes, it is, but it is really the Eaton design, and they made small drum models too with the clipped patent plate. I have one of those housings on my 1925.
