Frame 1917-1922 ?
Sanary22FT
First Name: Stephane
Last Name: Lezzier
* REQUIRED* Type and Year of Model Ts owned: Touring US 1918
Board Member Since: 2022
Frame 1917-1922 ?
Post by Sanary22FT » Mon Nov 28, 2022 3:25 pm
Hello,
How can we recognize a 1917-1922 frame ?
Regards
Kerry
Last Name: van Ekeren
Re: Frame 1917-1922 ?
Post by Kerry » Mon Nov 28, 2022 3:40 pm
From 1919/22 will have holes for the battery carrier.
Post by Rich Eagle » Mon Nov 28, 2022 3:46 pm
First, it would have the forged running board brackets with the rods running between them (until '21). '19 and later would have holes for a starter switch. Previous to '19 it would be much the same as the '15 frame. It would have 2 holes each side of the frame top for the firewall (dash) brackets as well as two holes in the side of the frame for the latter firewall brackets. The top holes were eliminated but I'm not sure when. (edited)
More clues to come from others, I'm sure.
Some details here.
http://www.mtfca.com/discus/messages/70 ... 1498331647
Gavin Harris (Napier, NZ) provided this chart several years back. It should help.
http://www.mtfca.com/discus/messages/33 ... 356806.pdf
Post by Rich Eagle » Mon Nov 28, 2022 4:07 pm
There is a lot of good information here if you have time to pour through it. It may answer some questions.
http://www.mtfca.com/discus/messages/33 ... 1366444998
http://www.mtfca.com/discus/messages/33 ... 1366355695
A bit too much for my slow brain.
Post by Allan » Mon Nov 28, 2022 5:16 pm
On our Canadian sourced cars, the pressed steel running board supports were introduced on the 1922 models, superseding the forged type used earlier.
Sanary22FT
Last Name: Lezzier
Post by Sanary22FT » Tue Nov 29, 2022 7:00 am
Thanks everybody
