What have you done with your Model T in April?
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Re: What have you done with your Model T in April?
Made a clamp on battery bracket for my earley TT.
varmint
- First Name: Vernon
- Last Name: Worley
Made some rivets and started assembling the rear panel bracket (coupe).
Vern (Vieux Carre)
varmint
- Last Name: Worley
Wife calls her Model T Olivia Hardy but I'm calling the rear end Jed because I had to "clamp it".
Vern (Vieux Carre)
Daniel828
- First Name: Daniel
- Last Name: Brennan
I had my first drive in my car yesterday. I have vid of it but can’t figure how to post a vid. So here’s a pic
It’s not done yet but it’s getting closer
Dan
Dan
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
I was inspired by Steve Jelf, and made a fuel shut off extension for the Fordor. I'll paint it black someday, so it blends in. No more crawling under the car, which was a hassle when it's inside the trailer.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
- First Name: Dallas
- Last Name: Landers
I had my son over this morning to help move some cars around. While I had it out of the shop, I snapped a couple photos in the sun.h
Ed Baudoux
Dallas, that looks amazing!!
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Thank you Ed. 1st time I have seen it out of the shop all in one piece also.
yukonjack
- First Name: Jack
- Last Name: Murray
- * REQUIRED* Type and Year of Model Ts owned: 1926 light express
Very nice, Paul...I have a soft spot for old stuff that was built to work for a living! What brand of wrecker hoist is that?
Regards, Jack
Mel King
- First Name: Melvin
- Last Name: King
I finally got the wind shield & the back two ribs of the top on my roadster. I am still looking for the front rib. MEL.
yukonjack
- First Name: Jack
- Last Name: Murray
Another nice workhorse brought out of retirement...beautiful job, Dallas!Dallas Landers wrote: ↑Sun Apr 28, 2019 6:15 pmThank you Ed. 1st time I have seen it out of the shop all in one piece also.
Took Nelly-Bell the Raloo Rocket out for a drive to seat the new rings. While not a hot day the moto-meter didn't show the engine getting real warm in fact was running a bit on the cool side. My ignition switch is getting flakey and that was the only issue. Had to run a jumper to get last few miles home. She no go with no fuel getting to carb or voltage getting to coil! LOL Did about 20 miles running around.
Randy SR
- First Name: Randall
- Last Name: Schultz-Rathbun
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster pickup
I've been having trouble making it up the hill to my house, so I pulled the plugs and cleaned and gapped them, and cleaned the timer. It didn't seem to be running any better, so used a plastic handled screwdriver and shorted the plugs one at a time. The #2 plug had no spark. Swapped #1 and #2 coils, and the dead spark plug moved to #1. Since I only have the four coils, I ordered a rebuilt coil from Lang's. I'll be shipping the bad coil off to the Coil Doctor tomorrow, so when it comes back I'll have a spare. I'm surprised the car drove as well as it did, seeing as how I've been running on 3 cylinders.
EricMac
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, '92 Stynoski, 'owner emeritus
I drove the 26 Touring a bit today. Only in Michigan can you wake up to snow on the ground and go for a T ride in thr afternoon.
Meanwhile the Eyre Torpedo continues to look more like a car. Today the painted hood was installed for the first time.
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor
1926 Depot Hack project
1927 Fordor
dykker5502
- First Name: Michael
- Last Name: Deichmann
I'm behind schedule, but have pulled the engine earlier this year on my 1922 Fordor. I have in April replaced the clutch plates and spring and put it all together, this time sure that the bolt on the hub is proper positioned in the hole in the shaft. I missed that 10 years ago apparently allowing the hub to slowly move out and removing the pressure on the clutch plates. That led to a slippery clutch. Have not driven it for 2 years.
Ford Model T 1914 Touring
Eric the Torpedo looks great!
Bob in Texas
- First Name: Bobby
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
Took 1924 Simms (built in San Antonio, Texas) Chemical Truck to car show. And won Mayor's Trophy. It was beautiful weather on the Texas Gulf Coast.
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
D Stroud
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Dallas, you're making me drool again!!! Text me those pictures when you get a chance. I want to share them with family and friends.
Dave
1925 mostly original coupe.
EricMac
- First Name: Eric
I can see why the chemical truck would win big. Its a beauty.
1913 Touring
1927 Fordor
1927 Fordor
NealW
- First Name: Neal
- Last Name: Willford
I have been making progress on my 15 Runabout restoration:
*Tore down my wheels, prepped the metal parts and sent them to Stutzman's for re-wooding
*Removed everything from the frame but the body and gas tank.
*Took my fenders in to a local company specializing in auto work for low pressure media blasting
*Got my running boards powder coated
*Disassembled the front and rear springs and took them in for blasting and powder coating
Topic author - Posts: 7411
I ended the month with a flurry of little chores on the 1923 touring. Replaced the five-year-old battery. Fixed the intermittent ignition/light switch so that when it's on it's on. Adjusted the low pedal so it doesn't bottom out on the floor. Found the brass tube housing for the speedometer sending unit was gone, so made a new one. Now I have to figure out why the other one disappeared.
EricMac
- First Name: Eric
Im prepping a wheel for paint. It's not a difficult job but is very time consuming.
1913 Touring
1927 Fordor
1927 Fordor
