Water pump
Brent Teltow
Topic author - Posts: 55
- First Name: Brent
- Last Name: Teltow
- * REQUIRED* Type and Year of Model Ts owned: 1917 touring 192
Water pump
Good evening, I have a speedster with a electric fan on it. Did they make a water pump that goes on the top radiator neck? It has a 12volt alternator on the side a water pump would go. Any suggestions would be great. Thanks Brent
- First Name: Henry
- Last Name: Lee
Re: Water pump
Do not know why you would need an electric fan even with high performance, but to each their own. The alternator mounts normally are higher than any water pump system unless someone made a homemade system. There were some weird ones here and their but the only one I found to move the volume was a 1932-36 Ford V8 one adapted for the water neck at the radiator. You might want to find an old Atlas water pump or a Bergs works well.
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
Re: Water pump
Yes there as a water pump that mounted in the neck. google "mtfca; NIMS"
https://books.google.com/books/content? ... 454&edge=0
http://www.mtfca.com/discus/messages/17 ... 1307166721
There was maybe one other, the name I do not recall. I think they made a 26/27 style too, but most were 25 back.
