Want to change the pan on my '14 roadster. I have a 4 dip 26/27 pan to use. Will I have any issues with the exchange?
frontyboy.
Pan Replacement
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Pan Replacement
No- it will interchange with any 3 dip pan with no issues. Just don't let Larry Smith see it! Paint it black so it does not show.................
Re: Pan Replacement
In reading about pan's sound like the 3 dip pan is stronger than the 4 dip
Since the '26 has a wider brake drum then wouldn't the pan and then the hogs head as well. And then pedal locations. If you don't have to replace the hogs head then as Dan said it will work... https://mtfca.com/phpBB3/viewtopic.php?t=12749
Kerry
- Last Name: van Ekeren
Re: Pan Replacement
I had a 4 dipper and a narrow nose pan that both had issues, so a cut and shut and now I have a 4 dipper with a narrow nose on my 16.
