Kerosene lamp dissassembly
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Dec 08, 2022 5:27 pm
How does this come apart? Penetrant?. Mine is stuck and has some hidden treasure rattling inside.
Last Name: Humble
Board Member Since: 2006
Re: Kerosene lamp dissassembly
Post by Humblej » Thu Dec 08, 2022 5:43 pm
Should lift out. Kroil will loosen it. You didn't ask, but to take the upper part of the lamp apart the top cap of the chimney unscrews from the chimney and the chimney, reflector, etc., all fall out. Soak the top cap threads in Kroil too.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Fri Dec 09, 2022 3:09 pm
The top brass part is crimped to the remainder, the whole assembly should lift out as one piece, as suggested just soak it and gently pry, maybe soak the base in kerosene for a couple of days. The burner assembly is brass and the fount is steel so there may be some rust from the fount.
