One complete Set of KR Wilson main bearing quick bolts for Model T and A Fords. These are used when fitting the main crankshaft bearings and allows the bearing caps bolts to be quickly tightened or loosened. Without these special bolts quite a bit of time is wasted putting in the stock main bearing bolts and tightening down the castle nuts to check the fit and clearance of the main bearings. With these bolts, keepers and special nuts it takes only a few seconds to tighten down the caps. They save a lot of labor when doing main bearing work.
This set includes four (4) long quick bolts for the front and center main caps, two (2) short quick bolts for the rear main cap, five (5) short handle and one (1) long stem keepers, and six (6) special nuts. These bolts are ready to use. $400 plus $10.40 USPS Priority Mail shipping.
FS: KR Wilson Main Bearing Quick Bolts
LOCParts
Topic author - Posts: 56
- First Name: Langs
- Last Name: OldCarParts
Re: FS: KR Wilson Main Bearing Quick Bolts
The Quick Bolts have been spoken for.
Thanks MTFCA!
Thanks MTFCA!
