exhaust manifold
Melba Nolan
Topic author - Posts: 1994
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
exhaust manifold
for sale: exhaust manifold Ford script $80 plus postage
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: exhaust manifold
Melba, Just a reminder that a photo and a note that says "looks good" doesn't cut it. You need to put a straight edge along the ports showing they are in perfect alignment or it could be an expensive bad experience for the buyer. A new, perfect one is not cost prohibitive. We need to start imposing specs of wear areas to protect our great hobby.
No disrespect,
Ken
P.S., That one looks sagged at #4.
No disrespect,
Ken
Work honestly
Stay true to your word
Get the job done right
Rick_Rice
- First Name: Rick
- Last Name: Rice
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Ken,
Maybe it's just me, but in the photos that clearly show the manifold sitting on the straight edge with all four ports on the same plane, she sure "looks good" to me. Maybe you need to get your eye sight checked before you criticize someone else's item for sale. We need to start imposing a bit more kindness with each other to protect our great hobby.
No disrespect and...
Kind Regards,
Rick Rice
Kind Regards,
Rick Rice
I agree with Ken that the manifold needs to be checked for warp across the face of the ports as well as across the bottom edges. Melba's photo shows a good bottom edge having no sagging. I borrowed the photo below from an old forum that shows a bit of warpage on the port circled.
- Attachments
- edge.jpg (81.55 KiB) Viewed 4120 times
Ken Buhler
- First Name: Ken
- Last Name: Buhler
Rick,
Rough cast does not allow for a good reading, the machining does. These are photos of a new manifold and a warped one.
I am kind, fair, honest and always willing to hear others opinions. Furthermore, I have had a few phone conversations with Melba and, I believe, we have a mutual respect for each other.
Ken
Ken
Work honestly
The only unkind words I'm reading in this thread are yours. Ken's photos show the correct way to check an exhaust manifold.
RGould1910
- Last Name: Gould
The manifold looks good to me as well.
I saw this earlier and the manifold looks good to me. I wouldn’t except used parts to be factory perfect. If I had a question about a used part I would contact the seller privately. The manifold is straight and when installed it would fit fine.
I've got to say, it looks straight to me too. FWIW
Mark Osterman
- Last Name: Osterman
The straight edge is not in a place that shows if it’s warped or not. It should be on the side of the holes and placed so that the straightedge is touching the bottom edge of all
the openings.
the openings.
Mark Osterman
Here is how you show a manifold with a straightedge to determine warp. This manifold is warped.
That's how I've always done it - align #1 & #4 and see where the middle is.
Is just checking port alignment across the bottom edge of the manifold all that is necessary to verify its serviceability and it is not possible for a manifold to warp across the port faces? https://www.mtfca.com/discus/messages/4 ... 1390268893
Melba, Why not include a photo across the ports, as done in the picture above, to end the discussion & get your scripted manifold sold.
Frank,TRDxB2 wrote: ↑Tue Dec 13, 2022 1:24 pmIs just checking port alignment across the bottom edge of the manifold all that is necessary to verify its serviceability and it is not possible for a manifold to warp across the port faces? https://www.mtfca.com/discus/messages/4 ... 1390268893
That's a valid check too. They seem to be more prone to warpage in the other plane however. (I might question how flat your I-Beam is, considering it appears to be the top of a hydraulic press. Wondering if repeated use of the press may have induced a slight arch in that beam.)
Melba Nolan
- First Name: Melba
- Last Name: Nolan
will try to do that today. My husband has been in the hospital for 13 days and I am a little behind.
Melba,Melba Nolan wrote: ↑Wed Dec 14, 2022 10:07 amwill try to do that today. My husband has been in the hospital for 13 days and I am a little behind.
I hope he gets to feeling better. Sorry for the drama that a simple exhaust manifold can cause.
Best wishes for the Holidays!
Bruce Compton
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
No need to apologize Melba. I came across a T vendor here in Canada that had 7 decent looking script manifolds that he swore up and down were not warped. Actually they were OK in one plane but badly warped in the other (vertically). I showed him how to check them and all 7 were not even close to being useable. The manifolds warp because many "mechanics" just use flat gaskets instead of the 2-piece ring and gland type that locates the ports properly to the block and prevents the manifold from drooping (warping).
Tim Moore
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
I always carried a piece of string at swap meets to check them. Just pull tight from the bottom edge of front port to bottom edge of back port. The middle ports should fall in line on the bottom if it is straight.
Tim Moore
Tim Moore
Melba Nolan
- First Name: Melba
- Last Name: Nolan
I am going to remove this item.
