drag link fix
drag link fix
Post by Allan » Tue Dec 13, 2022 2:27 am
I have been doing some maintainence on my 1912 chocolate van prior to some promotional work. I found a problem I have never before encountered.
The fixed end on the drag link was quite loose, and could be turned almost 1/2 a turn on the end. It appears to have never been riveted, and the bronze had let go. It is scary to think how long it has been like this.
I took the link off and washed it down before heavily wire brushing it clean at the loose end. Then I washed it and air blasted it to get the oil out from between the coupling and the yoke. I once bought two lifetime supplies of silver brazing rods at a liquidaton sale of a wedding supplies company This stuff has some silver content . It was formulated to wick in in close contact work like assembling bicycle frame tubing and rhe joint pieces. It wicked in well, from both the cup end and the rod end of the yoke. Then I riveted it just to be safe.
Perhaps there are others like it .
Re: drag link fix
Post by TXGOAT2 » Tue Dec 13, 2022 2:48 am
Any critical parts with that construction ought to be very carefully inspected.
Re: drag link fix
Post by Scott_Conger » Tue Dec 13, 2022 10:51 am
I think it was around mid year '12 when the riveted pin was added in addition to brazing
Re: drag link fix
Post by Allan » Tue Dec 13, 2022 4:31 pm
Doe anyone know how to shift this out of the parts forum?
First Name: Adrian
Last Name: Whiteman
Re: drag link fix
Post by A Whiteman » Tue Dec 13, 2022 4:49 pm
I think you will need to do a new post...
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: drag link fix
Post by Ken Buhler » Wed Dec 14, 2022 2:16 pm
I repaired a riveted drag link for a customer. What is the length of yours?
I will post about drag link repair in the general discussion forum with a similar header.
Ken
Work honestly
Stay true to your word
Get the job done right
