Now found thanks! WTB: KR Wilson Quick Bolts
Topic author - Posts: 69
- First Name: Alex
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1925
I’m looking for a set of quick bolts, keepers and nuts to complete my KR Wilson Combination Set up.
Please message me via the forum if you can assist. To do this, please click on my profile name and then either click on ‘send an email’ or ‘send private message’.
Thanks Alex
Thanks Alex
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: WTB: KR Wilson Quick Bolts
Alex, Langs had a set on here last week.
Work honestly
Stay true to your word
Get the job done right
The set Lang's had listed has been spoken for. Here is the link, there are photos in it just in case someone is not sure what they look like:
viewtopic.php?f=5&t=33355
I had wanted a set years ago. Being uncommon to find & expensive when found, I figured I could make a set.KiwiFordGuy wrote: ↑Tue Dec 20, 2022 5:53 amI’m looking for a set of quick bolts, keepers and nuts to complete my KR Wilson Combination Set up.
Thanks Alex
A fellow loaned me one of each part. They are not difficult to make or have made.
The studs were made from long allen bolts. & the nuts from coupling nuts. The stud locks were made from recycled axle shafts.
- First Name: Alex
- Last Name: Brown
Thanks for the comments and advice so far
much appreciated
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
If I may ask, what is the attraction for them in today's world?speedytinc wrote: ↑Tue Dec 20, 2022 11:21 amI had wanted a set years ago. Being uncommon to find & expensive when found, I figured I could make a set.KiwiFordGuy wrote: ↑Tue Dec 20, 2022 5:53 amI’m looking for a set of quick bolts, keepers and nuts to complete my KR Wilson Combination Set up.
Thanks Alex
I will confess that like you I wanted a set and finally found the bolts and the nuts, but had to make the keepers. Now that I have them, I rarely use them. With the modern age of cordless impact guns, I can install a set of caps quicker using the gun than I can using the Kwik Bolts.
They are real handy for timesavering mains.
- First Name: Brent
- Last Name: Terry
I guess I am naive.
BTW, he is a video of me burnishing in Model-A bearings, but I do it the same way. https://www.youtube.com/watch?v=PHRmJyq6JFY
Burnishing is different than timesavering. Timesavering involves a lot of cap removal to keep the babbit well lubed. Instead of completely removing the nuts, only a 1/4 turn is needed. Saves some time. I dont use a lathe. I turn the crank with a hand wheel. Your way is easier on the hands.
& besides, I'm a tool junkey.
- First Name: DAN
- Last Name: MCEACHERN
Hi Alex- I sent you a private message through the forum.
Dan
Dan
- First Name: Alex
- Last Name: Brown
Thanks to those who messaged!
