TT Hood Forner
BUSHMIKE
Topic author - Posts: 355
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
TT Hood Forner
When I see pics of the wood cab TT’s without a cowl, is there a hood former that the hood rests on?
- Last Name: House
Re: TT Hood Forner
Yes. It’s the steel firewall for Model Ts. TTs were introduced in ‘17-‘18 so they might have had wood firewalls but a few in ‘23 would’ve had the low steel firewall. Then, when a dealership sold a TT chassis in ‘24-‘27, they’d have a “high” steel firewall just like the cars.
BUSHMIKE
- First Name: Mike
Re: TT Hood Forner
So, is this why I see brass rivets around the perimeter of the firewall? I assume chafe welting was riveted on. So would the rear of the hood sat directly on the welting?
- Last Name: House
Re: TT Hood Forner
Yes
- Last Name: Humble
Re: TT Hood Forner
Early TT's were only sold as a chassis, latter TT's were available with open or closed cab bodies or as a chassis.
The firewall is the hood former for chassis, Ford bodies, and after market wood bodies.
BUSHMIKE
- First Name: Mike
Re: TT Hood Forner
Thanx for the help! Sorry about the spelling…..it will probably be a long time before I find an authentic Ford “forner”.
BUSHMIKE
- First Name: Mike
Re: TT Hood Forner
Interesting running board brackets. I have not seen those in my perusing of the web.
Re: TT Hood Forner
Mike
Re: running board brackets...
be careful with making any conclusions from Artist Renditions
they can be hilariously wrong sometimes
Duey_C
- First Name: Duane
- Last Name: Cooley
Re: TT Hood Forner
They sure are some funky looking running board brackets. Unless it was a tried and failed thing.
Artist's renditions sure can hold some stunning mistakes like Scott mentions! Then other times, they're spot-on accurate.
We joke about this in another world also.
I'd imagine this is what your more used to. Me too. Best I can tell these two pics are from '24 or so TT here.
This driver's side running board was likely moved out to fit the Group 2 battery bought and they ran with it.
Group 1 is the standard size. Smaller.
That pic of the early TT chassis is gorgeous! Coil box ign switch, radius rods over the front axle and those funky brackets!
BUSHMIKE
- First Name: Mike
Re: TT Hood Forner
Duey,
What are the partial brackets attached to the sides of the running board brackets in your pic? Is it part of the battery holder?
Two of my running board brackets have holes on same side. Guessing I have (2) of either the front or rear brackets on the same side?
BUSHMIKE
- First Name: Mike
Re: TT Hood Forner
I found my answer in another post with a TT battery holder pic posted by George House.
