I have aligned my Model A's but have never attempted to do this on my 1915 T. Can anyone share the proper method and the amount of tow in we need on the early T's?
Ron
Wheel Alignment on a 1915 Touring
Model T Ron
Topic author - Posts: 322
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Re: Wheel Alignment on a 1915 Touring
Here you go: https://dauntlessgeezer.com/DG104.html
Model T Ron
- Last Name: Bakow
Thank you. The method is very similar to the Model A and I like the information on making a tool.
Ron
Ron
Chris Barker
- First Name: Chris
- Last Name: Barker
Steve's tool is very elegant, but a tape measure works fine if you have a friend to help.
Check that neither front wheel has significant sideways run-out before you start.
ABoer
- First Name: Anthonie
- Last Name: Boer
I do it this way , no problem with sideways run out .
Toon
This is the best method, (in my opinion). Notice that the dimensions are taken with the front wheels back on the ground. I would even roll the car ahead a few feet before measuring.
