Radiator drain
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Radiator drain
Post by Mustang1964s » Thu Dec 29, 2022 12:08 pm
Well, the Rad drain only stops dripping when enough rust has built up.
Having drain the T for the winter, I pulled the drain.
This is what came off. Now I need to know what the thread size that I should use for the new one.
Does not look good. Just hope I can get a new one with good threads.
Re: Radiator drain
Post by RajoRacer » Thu Dec 29, 2022 12:13 pm
Original was 1/8" pipe.
Last Name: Humble
Board Member Since: 2006
Re: Radiator drain
Post by Humblej » Thu Dec 29, 2022 1:14 pm
Same drain as the oil pan, easy to find.
Re: Radiator drain
Post by Rich Eagle » Thu Dec 29, 2022 1:16 pm
Running a thread die down it might save it. Or even a little silver solder first.
"Just sayin".
Mustang1964s
Re: Radiator drain
Post by Mustang1964s » Thu Dec 29, 2022 1:40 pm
I need one that does not leak.
Unless there is a way that to rebuild this one, so it does not leak.
Re: Radiator drain
Post by RajoRacer » Thu Dec 29, 2022 1:50 pm
Lang's carries an excellent original style petcock - https://www.modeltford.com/item/3079.aspx
Re: Radiator drain
Post by speedytinc » Thu Dec 29, 2022 1:55 pm
Take it apart & lap with tooth paste.
Re: Radiator drain
Post by Jerry VanOoteghem » Thu Dec 29, 2022 2:35 pm
If it were the original style it might be fun to repair it, but it's not, so I would just replace it the new one from Lang's.
Mustang1964s
Re: Radiator drain
Post by Mustang1964s » Thu Dec 29, 2022 3:47 pm
That's what I am thinking.
Get a new one and run a tap thru the threads.
Keep fingers crossed that the rad is not messed up.
Re: Radiator drain
Post by Allan » Thu Dec 29, 2022 5:36 pm
That tap looks more like a carburetor drain cock. The pan oil taps are the same as the radiator drain cock, as others have indicated. I would run a tap in the radiator outlet before fitting any replacement. Something has damaged the thread on your draincock and it may be a damaged thread in the outlet.
Re: Radiator drain
Post by Steve Jelf » Thu Dec 29, 2022 10:56 pm
If you clean up the hole threads with a tap, don't overdo it. You only want to clean up the threads, not cut any new ones.
Last Name: House
Re: Radiator drain
Post by George House » Fri Dec 30, 2022 7:48 am
and wrap the threads of your new petcock with that plumbers white Teflon tape.
Mustang1964s
Re: Radiator drain
Post by Mustang1964s » Fri Dec 30, 2022 9:26 pm
Found a couple from an old oil pan.
I soaked them in WD40. They seem to move well.
Tomorrow I will check the rad.
