Transmission driving plate position
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Sun Jan 08, 2023 4:00 pm
I am in the beginning of an engine tare down for rebuilding on a 26. When unbuttoning,…removing the hogshead, it became apparent that the front of the ball cap had been touching the clutch spring support as both surfaces are scored.
This engine has been rebuilt not many miles ago, and has some other issues so this is not a huge surprise.
Wondering if anyone has a reference dimension for the driving plate position, how far should it extend in relation to the rear of the crankcase ?
Dave
First Name: craig
Last Name: leach
Re: Transmission driving plate position
Post by Craig Leach » Sun Jan 08, 2023 4:25 pm
Hi Dave,
Looks like you will be replacing the 3341 spring cup and 3342 pin that is most likely the issue.
Post by Mark Gregush » Sun Jan 08, 2023 9:31 pm
If the pin is installed in the cup at rear and is seated properly in the spring and the throughout bearing is installed the correct direction with fingers in the correct slot, the spring and associated parts would be in-between the drive plate and 4th main, not touching either. Sounds like Craig is on the right track, the pin and/or cup is missing allowing the spring to ride on the 4th main.
Last Name: Patrick
Post by jiminbartow » Sun Jan 08, 2023 10:22 pm
Exploded transmission drawings:
Kerry
Last Name: van Ekeren
Post by Kerry » Sun Jan 08, 2023 10:56 pm
The thrust ring that go's inside the spring cup was deleted by 1916.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Jan 09, 2023 8:06 am
There is short and long fourth mains, if you use the early driven plates you need to use the short fourth main.
Dave1
Last Name: Eddie
Post by Dave1 » Mon Jan 09, 2023 11:24 am
Thanks, all good advice
Dave
Post by Jerry VanOoteghem » Mon Jan 09, 2023 11:40 am
Many times, the notch within the spring cup, that the retaining pin nests in, will wear, allowing the cup to sit too far back and reducing the clutch spring pressure. In extreme cases, the pin wears completely though the cup, allowing the spring to push the cup back against the spherical portion of the 4th main. You usually have no high-speed clutch engagement when that happens.
Dave1
Last Name: Eddie
Post by Dave1 » Tue Jan 10, 2023 2:22 pm
Just so ya know…. Turns out for one thing the clutch disc drum was not installed far enough onto the transmission shaft.
The locking bolt on the disc drum is designed to fit into the hole in the shaft,locking the disc drum into position, in this case the locking bolt was above the hole, this allowed the disc drum to move to the rear.
Dave
Kerry
Post by Kerry » Tue Jan 10, 2023 4:43 pm
It's a wonder that the lip on the reverse drum against the band would let the transmission travel that far.
Post by speedytinc » Tue Jan 10, 2023 4:56 pm
Dave
The set screw is more a fail safe.(if properly installed) The clutch hub is supposed to be a press fit.
Either the clutch hub and/or transmission shaft will need replacing to maintain a press fit.
Kerry
Post by Kerry » Tue Jan 10, 2023 6:57 pm
Using the term "Press fit" is a little exstream, that gives a mental picture of using a press, the hub only requires as Ford puts it, drive the drum down, which is no more than a firm fit.
Post by Jerry VanOoteghem » Tue Jan 10, 2023 7:09 pm
A hard press fit is always what I've encountered.
Post by speedytinc » Wed Jan 11, 2023 8:29 am
Some are so tight, the T Z puller barely does the job to remove & will "taco" the clutch hub.
Installing takes a good bit of hammering to get in place.
