1919-22 Coupe Photos
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Jan 09, 2023 9:58 am
Hope everyone's having a fine Monday. I am looking for some photos of the space under the seat cushion on 1919-22 suicide door coupes. How much space should be there? Is it a storage compartment or is it somewhat useless?
And if you got a suicide door coupe you are proud of, share photos of the whole machine if you'd like. Now all of them are at least 100 years old.
MWalker
Last Name: Walker
Re: 1919-22 Coupe Photos
Post by MWalker » Mon Jan 09, 2023 10:37 am
FYI, 1923 Coupes are the same bodies as 19-22's.
Post by Rich Eagle » Mon Jan 09, 2023 11:44 am
These are some I took of mine. I believe it is close to correct.
M.Sinclair
First Name: Matthew
Last Name: Sinclair
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1919 Runabout
Post by M.Sinclair » Mon Jan 09, 2023 12:26 pm
Here is the frame they have at piquette.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Jan 09, 2023 1:47 pm
Thank you much for the photos, from what I can see the space under the seat is negligible.
Post by Rich Eagle » Mon Jan 09, 2023 2:15 pm
It's about the same as this coupelet.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Jan 09, 2023 3:12 pm
Thank you kindly Rich, that is very helpful. Maybe one could make a drop floor to increase the area of the compartment? Maybe not with the driveshaft there? I will do some more research and testing.
Post by Rich Eagle » Mon Jan 09, 2023 3:38 pm
There is a metal panel for the bottom. Mine had been cut for such a purpose. There is some room above the drive shaft or more on each side if you choose.
