Tappet Clearance
Topic author - Posts: 59
- Last Name: Delamater
- * REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Tappet Clearance
Rebuilding a spare engine and found on inspection that I am going to need to go to
oversize tappets .
What is the recommended clearance between the tappet stem and the valve
guide ?
Thank you.
oversize tappets .
guide ?
Thank you.
- Last Name: van Ekeren
Re: Tappet Clearance
That will depend on what valves, original or new replacement.
- First Name: craig
- Last Name: leach
Hi John,
Most of the suppliers sell a piloted reamer for the oversized tappets. I have found them to be a perfect fit. They are a little pricy
check with people you know they may have one. Or be in need and willing to share the cost.
Craig.
Craig.
- First Name: Art
- Last Name: Mirtes
I have a reamer. I can come to your house and do the job. I am only 5 miles away.
Art Mirtes
Art Mirtes
- First Name: Robert
- Last Name: Jablonski
....":::.…. Ooops
- First Name: Art
- Last Name: Mirtes
It is Art from Huron, Ohio who has the reamer and it is John from Huron, Ohio who needs a reamer. Many many miles from Arizona..
Oops! after re reading your question, the difference in terminology from each end of the world
tappet clearance would be the lash, but what you are asking is push rod clearance correct? Well Ford specs are STD diameter is .4355", to .4365" and push rod guide holes are .437" The 2 over size push rods are .015" and .030" OS.
- First Name: Art
- Last Name: Mirtes
John, you have my condolences on the loss of your mother which was shown in the local paper. I used to work with your brother Ti. He was well organized.
Art Mirtes
Art Mirtes
Art
Sent you several messages thru the forum.
I can be reached at roswellplastic@aol.com
Thank you
Johnr
Thank you
Johnr
- First Name: Art
- Last Name: Mirtes
John, I hope to call you soon for a visit. Sorry about not responding quicker.
Art Mirtes
Art Mirtes
