Spinning your wheels
Rich P. Bingham
Topic author - Posts: 1762
- First Name: Rich
- Last Name: Bingham
This one might be an '09 ? Flat belt off the rear wheel is powering something in that barn. I don't think I've ever seen a horn bulb mount like that one. Looks practical !
Get a horse !
- Last Name: Tannehill
- Board Member Since: 2002
Re: Spinning your wheels
I’d say late 9 based on the 2 bolt front body mount, tulip seats front & back, butterfly rear fender brackets are under the skirt not through the fender apron & tapered spokes. I can’t identify the side lights to big for JB 60’s & tiers are different, oil fonts are different. I’m relatively positive that the headlights are JB.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Looks like it may have the ford script with wings on the radiator, Piquette manufactured car?
- Last Name: Wrenn
Running boards look '09 as does the headlamp. Is that some sort of animal curled up in the driver's area? Too blurry to tell for sure.
Rich P. Bingham
- First Name: Rich
I think the Tourabout was not offered until July 1910 so it wouldn't be called a '09.
Correct me if I'm wrong.
The license plate looks like a 1912 Ohio if I am seeing it right.
Scott Rosenthal
- Last Name: Rosenthal
- * REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Like you said Tim, 09, based on 2 hole front body mounts, no reinforcing plate in radiator, and scalloped cut rear apron. Dog ID a bit tougher.
Kerry
- Last Name: van Ekeren
The Saturday evening post, August 1909, one of the 6 body styles for Fords.
I appreciate the picture, Kerry. According to the model T Ford encyclopedia, the "Tourabout shown in Ford Times but not produced until July, and then called 1910 cars."
"MODEL YEAR DATES: October 1908 to July 31, 1909. (Ford called the cars built after July 31 1910 models."
So, I was wrong about it being July 1910 but rather July 1909.
Sorry.
Sorry.
