High Speed TT
BUSHMIKE
Topic author - Posts: 354
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
High Speed TT
Does anyone have a pic showing the location of the “HS” stamp on top of the worm drive case? Id like to know what to look for.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: High Speed TT
TT’s weren’t marked. Some Model A housings were. It’s pretty rare to find high gears in anything but Ruckstells.
StevenS
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Re: High Speed TT
Mike, Ruckstells are more "likely" to have high gear sets in them, but not always. I also have found them in standard rear ends (found two so far in five rear ends). What I do if I am at an auction or inspecting one, is I will turn the input shaft and count the turns to see what type it is.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
BUSHMIKE
- First Name: Mike
Re: High Speed TT
An excerpt from the 1925 Encyclopedia…..July 8. I am just wondering what the stamp looks like.
- Last Name: Humble
Re: High Speed TT
Mike, as I read that entry dated Jul 8, that is what the Chicago Branch was doing, not Ford production.
micshotrodgarage
- First Name: michael
- Last Name: miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Re: High Speed TT
always have wanted to know if the Model AA high speed gears could be used in a TT. Is any of these parts interchangeable?
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: High Speed TT
I’ve found a few sets in early AA axles. As long as it’s still worm drive, they’re interchangeable. You can also just pull the back square cover off. With the worm gear bearing out, count the teeth. 6 teeth is high speed, 4 is low speed.
Brad
Brad
Adam
- First Name: Adam
Re: High Speed TT
I have found that they ARE NOT interchangeable. The couple of AA ring gears I've had were .200” wider than the TT ring gears and didn’t fit properly in the TT housings (they rubbed/locked up). The AA worm gears also were splined different on the front & didn’t match the TT drive shaft. I am wondering if the very early AA had carryover TT gears for a little while, but then were soon re-designed to make stronger? It’s not uncommon to see TT ring gears cracked open between teeth (likely from over-loading).
