Ford Script High Compression Head
Model T Ron
First Name: Ronald
Last Name: Bakow
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Post by Model T Ron » Mon Jan 30, 2023 9:07 pm
Does anyone make a high compression head with the Ford script and made is USA cast into it?
Last Name: Tannehill
Re: Ford Script High Compression Head
Post by JTT3 » Mon Jan 30, 2023 9:52 pm
Ron because licensing the Ford name cost the person more money making a product some consider that & leave it off. You’ll have to look at swap meets, the forum classifieds & tBay for ones produced late late 70s & 80’s. Reeder is the one person I can think of that made aluminum low heads with the Ford cast into the head.
Post by Allan » Mon Jan 30, 2023 11:03 pm
Ron, my Prus alloy head has the Ford script and Made in Canada. I added them. I made a little dam with plasticine for each word, and filled it with Devcon. Then i drew the lettering on the hardened Devcon and hand carved the lettering using an Exacto knife and my Dremel tool . It even has the casting date of the original iron head. Once painted, no-one has ever noticed it was there, let alone questioned the origins of the head.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Tue Jan 31, 2023 12:13 am
Here is the guy in Michigan that has new hi compression aluminum heads with Ford script and made in usa. These are the Z combustion chambers. He states that a model t engine will develop approx 27 horse power with this head. The new head holds an additional quart of water. The head weighs 15 pounds. The price is $330 including shipping and boxing. The Ford script is nice and sharp and well defined. I just received my 2nd head from him and the quality is perfect. The machined head surface is just a din finish, which is the same spec that I use on Ferrari's and Subaru aluminum heads.
contact, Steve Zajicek
586-983-9771(Warren Michigan)
You won't be dissapointed!!
frontyboy
Post by Allan » Tue Jan 31, 2023 1:08 am
Wasn't it Ralph Zajicek who made the Z head? Perhaps Steve is a son/relative. Z heads have been available for a long time.
Vonau
First Name: Beat
Last Name: Betschart
Post by Vonau » Tue Jan 31, 2023 3:09 am
Allan, I would be interested in your work. Do you have pictures of how you made the "Made in Canada"?
greetings from Switzerland
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Tue Jan 31, 2023 8:38 am
I’ve had a “Z” Head on my 1926 since 2004 and fingers crossed all is well!
Post by JTT3 » Tue Jan 31, 2023 9:16 am
Just asking, are the above mentioned heads low heads. I really don’t know. The OP has a 1915 T.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Jan 31, 2023 10:46 am
The only low head with Ford script that I know of is the Reeder Head. Out of production for decades now, they turn up in classified ads and at swap meets occasionally but getting really hard to find . I love mine.
Post by JTT3 » Tue Jan 31, 2023 10:58 am
Keith that was my thought but I mislabeled them as Reed, since corrected in my previous post, & you’re right it is a great head.
Post by Allan » Wed Feb 01, 2023 12:18 am
I had a Reeder head on my speedster, and it worked really well, until it blew a head gasket between now 2 and 3. The head has a large void in that location, which corresponds to nothing in the block. I had it plated/welded shut, and had the head surfaced. Never had another problem. A mate in New Zealand had exactly the same experience.
Post by Allan » Wed Feb 01, 2023 12:22 am
Vonau, I did not take pictures when doing the work. I copied the embossing from the original cast iron head that was on the motor, and included the casting date, just because I could!
Post by TRDxB2 » Wed Feb 01, 2023 12:46 am
Last Name: Juhl
Post by Oldav8tor » Wed Feb 01, 2023 11:14 am
I have a Z head on my '17. It does have "Ford" cast into it. The engine has been run on a dyno and achieved 27.32 HP at 1750 rpm with a NH carburetor, 22.65 HP at 1750 rpm with a Holley G.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Feb 01, 2023 6:17 pm
The 'Z' Heads have always been high heads and had Ford Made In USA on them. Prus heads are high heads and are plain with no markings. They are the only heads being produced (in stock configuration) presently that I'm aware of.
Post by Allan » Wed Feb 01, 2023 6:27 pm
"In stock configuration" If this is a reference to external appearance, they do look like standard heads, minus the lettering in some cases.
There is nothing stock about any of the combustion chambers. That is the whole purpose of their manufacture.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Feb 01, 2023 6:32 pm
Allen, I was referring to external appearance. I have one of both heads and do know the combustion chambers are different.
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Wed Feb 01, 2023 7:39 pm
I'd love to see a photo if you have one handy.
Post by Allan » Wed Feb 01, 2023 11:31 pm
Photos as requested.
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Wed Feb 01, 2023 11:46 pm
Let me correct a previous post that new heads with Ford script not made anymore WRONG!!!! I just purchased my 2nd one and had it delivered last week. It is true that from time to time they might not have one in stock but a couple of weeks after you order and its on the way to you.
frontyboy.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Feb 02, 2023 8:58 am
That is excellent craftsmanship, Allan. Very well done.
Arbs
Last Name: A
Post by Arbs » Thu Feb 02, 2023 11:45 pm
Nicely done!
