Support Forum
Mel King
- First Name: Melvin
- Last Name: King
Post
by Mel King » Sat May 04, 2019 11:08 am
I have seen it somewhere ,but I can not find it now. Is the torque for the mains 45 foot lbs?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Post
by Dan McEachern » Sat May 04, 2019 11:16 am
That's probably a little on the low side. I've used 60 ft-lbs for many years.
Post
by Mark Gregush » Sat May 04, 2019 11:33 am
Same as the Model A, 80.
Philip
- First Name: Philip
- Last Name: Thompson
Post
by Philip » Sun May 05, 2019 10:36 am
Since Ford gave no torque specs I just use the
Sae. Chart that goes by bolt size and pitch
