Front Axle
BUSHMIKE
Topic author - Posts: 356
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Front Axle
Anyone in the U.P. or Northern Wisconsin have a nice later Model T front axle?
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Re: Front Axle
I have quite a few in northern Il, Bob
BUSHMIKE
- First Name: Mike
Re: Front Axle
Too far to drive. Thats 7-8 hours one way
Re: Front Axle
Perhaps it would be useful to responders if they knew exactly how badly you needed an axle and exactly how far you'd drive to get one if they are not in your immediate vicinity.
That will weed out a lot of excess helpfulness.
It is a rare axle which cannot be repaired, so if you have an axle in hand, you might be better off trying that. I am pretty sure there at least a few knowledgeable fellows somewhat near you who would be willing to help with the repair. You might try asking for help in the general Forum.
BUSHMIKE
- First Name: Mike
Re: Front Axle
UP or Northern Wisconsin seems pretty specific to me Scott? I see no purpose in boring readers with a detailed description of my welded axle. As my original post indicates…..I am looking for a nice later style front axle.Scott_Conger wrote: ↑Mon Feb 06, 2023 11:34 amPerhaps it would be useful to responders if they knew exactly how badly you needed an axle and exactly how far you'd drive to get one if they are not in your immediate vicinity
Re: Front Axle
Good luck with the project
Re: Front Axle
Putting things in perspective since you are not from this part of the country ... UP abbreviation for Upper Peninsula of Michigan. Mike has Trout River MI as his location in the Forum. Thought I see how remote that is. Circle is about 3 hours away. Not many major roads eitherScott_Conger wrote: ↑Mon Feb 06, 2023 11:34 am.....an axle and exactly how far you'd drive to get one if they are not
- Attachments
- upmo.png (131.34 KiB) Viewed 1788 times
BUSHMIKE
- First Name: Mike
Re: Front Axle
You nailed it Frank. Thats a good driving radius. Isle Royal is gonna be tough though
. The reality of it is, inside that circle are several hundred T front axles in fields, barns, scrap piles and garges.
- Last Name: Hatch
Re: Front Axle
I knew there was a lot of T guys in around Marquette. There may still be some. Most not on internet. Dan
