1915 Model T Touring car, possibly a rare “wide track” model originally sold in the Southern States. Car has a slightly wider wheelbase (~4 inches), which was originally designed for following cotton wagon ruts in the road. Uncommon, period correct suspension damper setup.
Engine and transmission were rebuilt (aluminum pistons, .270 cam, lifter, valves, etc.). Engine casting date is 11 16 14. Engine starts and runs on battery or magneto. No generator/alternator setup but the battery has a trickle charger attached. No starter setup; has the original reinforced aluminum hogshead. Coils and carburetor rebuilt in the last few years. Recently changed Scandinavian cotton bands. Fresh kingpin and steering bushings. Oil screen filter with magnet. Freshly rebuilt rear suspension and rear axle with new brake cams, ring/pinion, thrust washers, seals, and a modern pinion bearing assembly (no more nasty bearing sleeve). Refreshed Klaxon horn. Added a quarter turn fuel shutoff valve before the carburetor. Boiled/cleaned radiator and fuel tank. Four new tire inner tubes, two new tires (other tires in good shape). Four new wheels made by Stutzmann Wheel in Ohio. Body wood is in good shape. Lots of small bits and pieces replaced.
Car runs well and is original in spirit. Beautiful ivory and root beer paint scheme with a white top in very nice condition. Good for wedding/engagement photos. I would keep it if I had the space, but I’m only allowed one at a time! Asking price is $15,000. Located in El Cajon, CA.
SOLD.....1915 Model T Touring, $15,000 OBO
Model T Ron
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Re: SOLD.....1915 Model T Touring, $15,000 OBO
What did you get for it......asking because I have a 15 Touring
- Last Name: Wrenn
Ron, your beautiful touring is probly worth close to $20-22K. If for no other reason, it's CORRECT looking! And your white tires, well, they're just the cat's butt!! LOL
Model T Ron
- Last Name: Bakow
- Last Name: Wrenn
Model T Ron
- Last Name: Bakow
So true Tim.....forgot about polished brassTWrenn wrote: ↑Tue Feb 07, 2023 8:51 am![]()
Oh no no..Probably $8K!!! Polished brass...add another $3K!!!
erkbrn
Topic author - Posts: 71
- First Name: Eric
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
Sold for ~$14k. Took some off because the radiator needed some work (or possible replacement). The gentleman that bought it isn't really a T person, but (I believe) has/is part of a business that rents cars out for events. Mutual connection through family was the only reason I was able to sell so quickly.
