Much has been posted to the forum on tips and tricks for mounting tires, but
I don't recall reading anything about difficulties encountered when removing clincher tires, other than some reported having had to cut off ancient, rock-hard tires.
It's time to change my worn out T-drivers that have been on the car for a dozen years and never dismounted. The bead has grown to the rim so tightly it would have been impossible to make a roadside repair ! I'm having an awful time trying to pry the bead from the rim on the outside edge, and can't forsee any way to wrestle with it on the inside. I suppose it would mean removing the wheels from the car.
Does anyone have wisdom to share that may help ? The tires are pliable with no weather-checking, so I'm loth to cut them off if they could be reasonably dismounted.
I should note these are non-demountable rims on my '13.
