Wench?
Keith Daniels
Topic author - Posts: 80
- First Name: Keith
- Last Name: Daniels
- * REQUIRED* Type and Year of Model Ts owned: 1927 TT Truck, 1926 Touring
Mark Nunn
- Last Name: Nunn
Re: Wench?
I have a drawer full of these and have no idea of what is correct. But I would suggest that you correct the spelling of your thread. It's inviting off-color remarks, like this one.
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Re: Wench?
Last edited by Shannon_in_Texas on Fri Feb 10, 2023 9:34 pm, edited 1 time in total.
- Last Name: Tannehill
- Board Member Since: 2002
Re: Wench?
There are many styles but most will have Ford somewhere on them, Ford appears to be in the center of the top jaw of the one you found. I haven’t seen one like that I don’t think. Nice find though. On the attached picture you’ll see the wench on top of the Ford.
Re: Wench?
Those wrenches are good for a display, but not very good for using on the car. They tend to slip and round off the nuts or bolt heads.
tdump
- First Name: Mack
- Last Name: Cole
Re: Wench?
what does the end of the handle fit in? I should know but I can't think of it
TFan
- First Name: Jim
- Last Name: Riedy
Re: Wench?
26-27 T and model A I believe, the square end is for the differential plug. Jim
Re: Wench?
Jim has it correct. The same tool with the square on the handle end, fits the 27 T differential plug, and the A model. Moore also made some of the earlier versions of this tool. The Ford script is found on many, and there were also other makers. Some had the T tool number cast in the handle or even on the fixed head of the handle. If your car is earlier than 1926, one without the square end is called for.
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
Re: Wench?
While both Wench styles historically
Pre-date the Model T …
The original Wench ….
Would likely prove to be more practical
Than the later version usually found
serving Libations in Taverns
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- Last Name: Wrenn
Re: Wench?
Ha ha Jim! Yeh, his mis-spelled word got me to look here for "something else"
FreighTer Jim
Re: Wench?
Great Minds Of Debauchery Think Alike
FJ
Moxie26
- First Name: Robert
- Last Name: Jablonski
Re: Wench?
I was led to believe that wrench was upgraded and issued for the Model A Ford to adjust the service brake at each wheel.
Re: Wench?
I'm sure you meant wrench. Not all 26-27's used the new style filling plug.
5 WoodenWheels
- First Name: Gerrit
- Last Name: Marks
Re: Wench?
I’ve heard several people refer to a winch as a “wench.”
They’ll ask if I have a wench.
I have to reply, “sadly, no.”
Keith Daniels
- First Name: Keith
Re: Wench?
I don't plan on using, at least not the wrench (spelling correct this time) part, but the plug end may come in handy.
