Wench?
Topic author - Posts: 80
- First Name: Keith
- Last Name: Daniels
- * REQUIRED* Type and Year of Model Ts owned: 1927 TT Truck, 1926 Touring
- Last Name: Nunn
Re: Wench?
I have a drawer full of these and have no idea of what is correct. But I would suggest that you correct the spelling of your thread. It's inviting off-color remarks, like this one.
- First Name: Shannon
- Last Name: Helm
Re: Wench?
Last edited by Shannon_in_Texas on Fri Feb 10, 2023 9:34 pm, edited 1 time in total.
- Last Name: Tannehill
Re: Wench?
There are many styles but most will have Ford somewhere on them, Ford appears to be in the center of the top jaw of the one you found. I haven’t seen one like that I don’t think. Nice find though. On the attached picture you’ll see the wench on top of the Ford.
Re: Wench?
Those wrenches are good for a display, but not very good for using on the car. They tend to slip and round off the nuts or bolt heads.
- First Name: Mack
- Last Name: Cole
Re: Wench?
what does the end of the handle fit in? I should know but I can't think of it
- First Name: Jim
- Last Name: Riedy
Re: Wench?
26-27 T and model A I believe, the square end is for the differential plug. Jim
Re: Wench?
Jim has it correct. The same tool with the square on the handle end, fits the 27 T differential plug, and the A model. Moore also made some of the earlier versions of this tool. The Ford script is found on many, and there were also other makers. Some had the T tool number cast in the handle or even on the fixed head of the handle. If your car is earlier than 1926, one without the square end is called for.
- Last Name: Jarzabek
- Board Member Since: 2008
Re: Wench?
While both Wench styles historically
Pre-date the Model T …
The original Wench ….
Would likely prove to be more practical
Than the later version usually found
serving Libations in Taverns
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Re: Wench?
Ha ha Jim! Yeh, his mis-spelled word got me to look here for "something else"
Re: Wench?
Great Minds Of Debauchery Think Alike
FJ
- Last Name: Jablonski
Re: Wench?
I was led to believe that wrench was upgraded and issued for the Model A Ford to adjust the service brake at each wheel.
Re: Wench?
I'm sure you meant wrench. Not all 26-27's used the new style filling plug.
- First Name: Gerrit
- Last Name: Marks
Re: Wench?
I’ve heard several people refer to a winch as a “wench.”
They’ll ask if I have a wench.
I have to reply, “sadly, no.”
- First Name: Keith
Re: Wench?
I don't plan on using, at least not the wrench (spelling correct this time) part, but the plug end may come in handy.
