Ez slider
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Ez slider
Post by Don ellis » Wed Jan 25, 2023 7:04 pm
Anyone have the measurements of this by chance? I have an older set of Rocky Mountain brakes I would like to update.
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Re: Ez slider
Post by Bill Robinson » Wed Jan 25, 2023 7:21 pm
Our best Model T suppliers stock them for around $20. It sounds like you might be wanting to make one yourself. Heck- you can't make a homemade one for that little bit, if your time means anything. But, if you are like me, you may want to just to see if you can. :lol:
Don ellis
First Name: Don
Last Name: Ellis
Re: Ez slider
Post by Don ellis » Wed Jan 25, 2023 7:30 pm
If it was twenty it would be a no brainer, but its over sixty and I can make one pretty easily.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Ez slider
Post by BE_ZERO_BE » Thu Jan 26, 2023 8:55 pm
It's 7.75" overall length
Respectfully Submitted,
Be_Zero_Be
tdump
First Name: Mack
Last Name: Cole
Re: Ez slider
Post by tdump » Thu Jan 26, 2023 9:03 pm
that appears to be a square nut,some flat plate,some threaded rod,a nut and some other stuff.about a hours work. I aint never made 70 bucks a hour! :D
Don ellis
First Name: Don
Last Name: Ellis
Re: Ez slider
Post by Don ellis » Thu Jan 26, 2023 10:18 pm
Thanks be_zero_be
tdump
First Name: Mack
Last Name: Cole
Re: Ez slider
Post by tdump » Fri Feb 10, 2023 7:20 pm
Well Don,show us a picture of yours now that you may have had time to make it. I can't blame you for wanting to make that simple part
Don ellis
First Name: Don
Last Name: Ellis
Re: Ez slider
Post by Don ellis » Fri Feb 10, 2023 8:26 pm
Works like a charm
tdump
First Name: Mack
Last Name: Cole
Re: Ez slider
Post by tdump » Fri Feb 10, 2023 10:30 pm
Good! glad to read that , that is 1 of many parts of this hobby I enjoy,is the fabricating,creating,problem solving.
Anyone can slide the lexan loan shark but it takes talent and knowledge and learning to do things this way
First Name: craig
Last Name: leach
Re: Ez slider
Post by Craig Leach » Sat Feb 11, 2023 12:02 am
Mack,
Lexan loan shark :lol: :lol: :lol: :lol: I only have one for the times you need one ( hotel, air, car rental & online purchases that will not
take a check) I pay it off every month. The cradit card Co. offered me a free credit check & I found out I don't have a credit rating anymore.
I'm thinking that's a win. If I couldn't do 95% of the work on my T's I don't think I would have one.
Don ellis
First Name: Don
Last Name: Ellis
Re: Ez slider
Post by Don ellis » Sat Feb 11, 2023 7:27 am
I made it out of scrap I had in the metal pile, It took about an hour. That’s an easy way to save sixty bucks. Im glad the parts suppliers have them for folks that can’t make them though.
tdump
First Name: Mack
Last Name: Cole
Re: Ez slider
Post by tdump » Sat Feb 11, 2023 9:34 am
Yea it is perfectly understandable that not everyone can make everything for sure.
If it weren't for my "stash" of metal and parts and sources for more,I wouldn't have much as far as a hobby car or anything else.it would be cost prohibitive.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Ez slider
Post by BE_ZERO_BE » Sat Feb 11, 2023 1:17 pm
The soul of the Model T is the Shade-Tree fabrication used to keep it going. :D
Be_Zero_Be
AndyClary
First Name: Andrew
Last Name: Clary
Re: Ez slider
Post by AndyClary » Sat Feb 11, 2023 2:52 pm
I’ve made a few of these. I increase the adjuster size from 5/16” to 3/8”. 5/16” all thread is down to almost 1/4” at its root with 18 stress risers per inch. I use a quality 3/8” SAE stud for far greater strength because, it’s brakes.
Andy
dobro1956
First Name: Donnie
Last Name: Brown
Re: Ez slider
Post by dobro1956 » Sun Feb 12, 2023 10:15 am
I also built one. I also used 3/8 threads. If I remember right, I think the one that came with my brakes was only 1/4 inch and looked weak to me. It's a "pushing, not pulling" part. I have seen the smaller threaded rod bent.
RGould1910
Last Name: Gould
Re: Ez slider
Post by RGould1910 » Sun Feb 12, 2023 10:56 am
Anyone ever use two of these for 27 parking brakes to increase the throw on the handbrake lever?
In my situation, the brake lining is too close to the drum surface resulting in the brakes being activated too soon when I pull on the lever. If I loosen the rods to eliminate early engagement, the car won't slip into high with the handbrake brake released. Its not an adjustment issue.
