How to get your speedster to 90 mph.
Topic author - Posts: 162
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Strap it to an eastbound trailer on I90 in Montana. Finally getting it moved to it's new home.
Re: How to get your speedster to 90 mph.
Try jumping the Grand Canyon.
I think you will exceed 90 before you hit the bottom, if you get a good run @ it.
- First Name: Les
- Last Name: Schubert
This car is certainly capable of that on the highway. I personally only had it to 75, but the guy I sold it to got a ticket at 92 and he had backed off!!
Sean,
Show us more of it!!!
- First Name: Sean
- First Name: Sean
- First Name: Sean
I will be posting more as it gets to be road worthy, but that may be a time down the road. New business to get established.
Very cool! Looks as if it has a lot of gear shifts?
- First Name: Sean
It has a Starr Planator. Found that out on this forum. Thought I had a Ruckstell until I was schooled.Jerry VanOoteghem wrote: ↑Thu Feb 16, 2023 5:48 pmVery cool! Looks as if it has a lot of gear shifts?
- Last Name: Pharis
The Ash wire wheels are a good start at making the car stable at higher speeds… but I’m afraid with just a low head for speed equipment yur gonna need to stick with the trailer
90 MPH? No problem! Add a supercharger and propane fuel system, a Marvel Mystery Oil injector, a Scat crank, rods, mains, modern flywheel, oil pump, forged pistons and under/direct/over Warford with a '48 u-joint. Don't forget the water pump, radial tires, drag chute, Plum Crazy paint job, and waterless coolant!
- First Name: Mack
- Last Name: Cole
And good health insurance!
- First Name: Sean
The guy who sold it to my father in-law told him it would do 70 with the Planitor in direct and that it was installed backwards for an overdrive to 110.TXGOAT2 wrote: ↑Fri Feb 17, 2023 10:07 am90 MPH? No problem! Add a supercharger and propane fuel system, a Marvel Mystery Oil injector, a Scat crank, rods, mains, modern flywheel, oil pump, forged pistons and under/direct/over Warford with a '48 u-joint. Don't forget the water pump, radial tires, drag chute, Plum Crazy paint job, and waterless coolant!
I think someone's leg was being pulled.
- First Name: Sean
- First Name: Sean
Was missing one hubcap. Found two Ash wheels/one cap on TBay. Shipping from Murdo SD cost me $50+. One year later I moved to Custer SD. Oh well. Still $ well spent.Kevin Pharis wrote: ↑Thu Feb 16, 2023 10:56 pmThe Ash wire wheels are a good start at making the car stable at higher speeds… but I’m afraid with just a low head for speed equipment yur gonna need to stick with the trailer![]()
