For Sale: Stevens, NY T-155 Rear Axle Roller Bearing Sleeve Puller. This is the sturdiest, heaviest, highest quality and most effective roller bearing sleeve puller ever designed for the Model T. It securely locks into the grease hole in a sleeve and will not slip out. The hole at the top of the puller is large enough to accept a long steel bar so enough torque can be applied to remove the most stubborn of axle sleeves. This hard to find tool is in excellent condition. $300 plus shipping.
FS: Stevens T-155 Axle Sleeve Puller
LOCParts
Topic author - Posts: 56
- First Name: Langs
- Last Name: OldCarParts
Re: FS: Stevens T-155 Axle Sleeve Puller
The Stevens T-155 Sleeve Puller has been spoken for.
Thanks MTFCA!
Thanks MTFCA!
