FS: 5-Z-287 Genuine Ford Rear Wheel Puller
LOCParts
First Name: Langs
Last Name: OldCarParts
Post by LOCParts » Sat Feb 18, 2023 9:32 am
For Sale: 5-Z-287 Genuine Ford Rear Wheel Hub Puller for Model Ts with wood spoked wheel. This example is a bit different because the name “Ford” is embossed on the puller body rather than sunk in which is more commonly found. The puller is in excellent condition, almost like new. The internal threads which engage the hub cap threads are in perfect condition. The pressure screw is also in very good condition. The square corners are sharp, not rounded over. When properly used, this puller will remove the most stubborn rear wheels. $85 plus shipping.
Re: FS: 5-Z-287 Genuine Ford Rear Wheel Puller
Post by Scott_Conger » Sat Feb 18, 2023 10:36 am
email sent
LOCParts
First Name: Langs
Post by LOCParts » Sat Feb 18, 2023 10:48 am
The 5-Z-287 has been spoken for.
Thanks MTFCA!
