Interesting Generator
got10carz
Topic author - Posts: 579
- Last Name: Meixner
Found this in my junk. Someone put a T front cover on a Chevrolet generator. This got me thinking about a distributor on a T. Problem is a T engine crankshaft gear has a different tooth count on the crank gear VS the generator gear. This would have to be corrected on the distributor drive.
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Interesting Generator
I have one with the disturbutor and have used it. Worked fine.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
