Stevens Front Axle Tool; Complete set
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Sun Mar 05, 2023 3:27 pm
This is a complete set with enough top and bottom bushings for three axles. You can buy these new; you'll spend a bit over $700 for the pieces (I did!) Price is $575 plus shipping. This will fit in a medium USPS flat-rate box.
havnfun
First Name: Joe
Last Name: Kowalczyk
Re: Stevens Front Axle Tool; Complete set
Post by havnfun » Sun Mar 05, 2023 3:38 pm
There is a brass washer that goes on the bit when installing the bits in the frame to protect the frame, do you have it.
Regards,
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Sun Mar 05, 2023 3:47 pm
I'm not sure what bit you're referring to; there is a reamer and a tap. There is a steel washer that's in the box, not a brass one.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Mar 05, 2023 4:32 pm
I'll take it Gary. Email sent.
havnfun
First Name: Joe
Post by havnfun » Sun Mar 05, 2023 4:40 pm
The washer should slide on the bit prior to sticking the bit into the frame, the washer is between the bit and frame hope this explains the washer
Regards,
Last Name: Tannehill
Post by JTT3 » Sun Mar 05, 2023 4:44 pm
Mark that was a smoking deal!
havnfun
First Name: Joe
Post by havnfun » Sun Mar 05, 2023 4:51 pm
Regards,
Last Name: Hatch
Post by Dan Hatch » Mon Mar 06, 2023 10:10 am
Original Stevens thrust washers are steel. New ones are BRONZE, make from old Front Spindle bushings.
Next to checking axle for hardness before reaming it, this is most important thing you need. I have heard of original frames being ruined by forgetting to use the thrust washer. Dan
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Mar 06, 2023 10:16 am
Missed out. Still looking. Dan have any plans on another run of these?
havnfun
First Name: Joe
Post by havnfun » Mon Mar 06, 2023 11:13 am
Dan,
Thanks for the clarification, my washer came with the reamers I bought from you or the frame when I bought it, I don’t remember for sure.
Regards,
Last Name: Hatch
Post by Dan Hatch » Mon Mar 06, 2023 4:19 pm
Came from me.
Mark : Sorry no plans for any more at this time. Dan
