Stevens Front Axle Tool; Complete set
Topic author - Posts: 346
- First Name: Gary
- Last Name: London
This is a complete set with enough top and bottom bushings for three axles. You can buy these new; you'll spend a bit over $700 for the pieces (I did!) Price is $575 plus shipping. This will fit in a medium USPS flat-rate box.
- First Name: Joe
- Last Name: Kowalczyk
Re: Stevens Front Axle Tool; Complete set
There is a brass washer that goes on the bit when installing the bits in the frame to protect the frame, do you have it.
Regards,
- First Name: Gary
- Last Name: London
I'm not sure what bit you're referring to; there is a reamer and a tap. There is a steel washer that's in the box, not a brass one.
- Last Name: Chaffin
I'll take it Gary. Email sent.
- First Name: Joe
The washer should slide on the bit prior to sticking the bit into the frame, the washer is between the bit and frame hope this explains the washer
Regards,
- Last Name: Tannehill
Mark that was a smoking deal!
- First Name: Joe
Regards,
- Last Name: Hatch
Original Stevens thrust washers are steel. New ones are BRONZE, make from old Front Spindle bushings.
Next to checking axle for hardness before reaming it, this is most important thing you need. I have heard of original frames being ruined by forgetting to use the thrust washer. Dan
Missed out. Still looking. Dan have any plans on another run of these?
- First Name: Joe
Dan,
Thanks for the clarification, my washer came with the reamers I bought from you or the frame when I bought it, I don’t remember for sure.
Regards,
- Last Name: Hatch
Came from me.
Mark : Sorry no plans for any more at this time. Dan
