My 1927 Model T Coupe Restoration
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
Re: My 1927 Model T Coupe Restoration
Getting the fenders on, if I can get my grandson to work!!! He decided to help so here is the result!!
BLB27
- First Name: Bruce
- Last Name: Brakke
Just some more pics of progress in the restoration.
Really nice! Be sure after you install the radiator and coil box to try to start the engine and get any bugs or etc taken care of. It’s a lot easier to get it all tuned up with the fenders off the car and everthing is easy to get to. Keep up the great work.
BLB27
- First Name: Bruce
- Last Name: Brakke
Sorry about the duplication!!!
BLB27
- First Name: Bruce
- Last Name: Brakke
Nine coils came with the T when I purchased it in 1954. Eight of the coils tested OK for restoration. I had the "Coil Man" restore five and the other three will be kept for future restoration if needed.
BLB27
- First Name: Bruce
- Last Name: Brakke
New Day Timer, grandson hooking up timing wires to coil box, and the license plate found at the Iowa State Fair.
BLB27
- First Name: Bruce
- Last Name: Brakke
Timing wires hooked up, radiator on and hoses attached, and grandson putting oil and anti-freeze in.
...fan belt?
On the coilbox, you may want to swing your #1 & #4 sparkplug wire terminals away from the coilbox mounting arms.
This is getting exciting!
BLB27
- First Name: Bruce
- Last Name: Brakke
Just a photo of the horn that came with the T when I got it in 1954. I have been told it is not a Ford T horn, but I like the sound.
- Last Name: Tannehill
- Board Member Since: 2002
I would strongly encourage you to put a fuse in the positive line going to the switch.
BLB27
- First Name: Bruce
- Last Name: Brakke
Seat back upholstery photos. The corner in the last photo is not finished.
BLB27
- First Name: Bruce
- Last Name: Brakke
Some photos to update the restoration. Carb heat pipe and engine.
Distagon2
It's looking like a car! Looking fabulous, it reminds me of when I restored my 26 Coupe back in 1980-81. Mine needs refreshing after 42 years.
